This is going to be my first time doing this and I need a little help getting started. This is what I'm wanting to do.
I want the visible stock aluminium parts polished, like the Intake manifold, Alternator, A/C, A/C lines,... http://www.caswellplating.com/buffs/alpolkit.htm Is that all I need? Do I need to do any sanding to make the parts smooth. Thanks for any help! Adam |
what do I use to start wheeling?
http://img.photobucket.com/albums/v6...uthrt/logo.jpg '98 CC Flame Red R/T- Hotchkis Coils powder coated Red, Spintech side exit catback, K&N FIPK, 52 F&B TB, Chrome R/T rims, interior done in Black Suede |
sorry for the assumption. this kit is for use with a drill motor preferably corded. cordless drill mostly dont have the speed to do polish work. if you have a drill in the 2500- 7500 rpm range that will work fine. as for the dremel i use one myself but they lack the torque to get the job done quickly. i also use a air die grinder if you have one of those it will work fine. if you have a compressor and no die grinder they can be picked up at numerous local tool stores and home improvement stores. the kit you asked about is all 1/4" shanked so the dremel you have will fit with these pieces. lastly if you have a bench grinder you can get adapters to convert it to a buffing machine.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
i would start by reading http://www.caswellplating.com/buffman.htm
This will help you get started... Good luck with the alt .. Have all the parts glass beaded then hand sand to 600 grit |
| Copy Chrome on engine parts and plastic, alot of can I's | cgworth | Copy Chrome Kit Customers Only | 3 | 08-29-2005 01:38 PM |
| a few polished parts Better than chrome !!! | customandsound | Metal Polishing Questions | 7 | 07-19-2005 12:50 PM |
| Help cleaning just polished parts | bonesaz | Metal Polishing Questions | 3 | 10-12-2004 07:58 PM |
| streamlining sanding of cast aluminium parts | rotorman | Metal Polishing Questions | 6 | 05-22-2004 01:09 AM |
| directions for polishing the aluminium parts on my sportbike | mrnasti69 | Metal Polishing Questions | 1 | 04-29-2003 09:12 AM |
