Ok, did my first polishing job last weekend. Just the ends of a valve cover. Turned out real nice.
Bead blasted clean with 80 grit. then went to 120-220-400-800-1000-2000 using a small orbital hand sander. Then used a automotive polishing liquid compund with a 4 inch polishing wheel. Came out great. This was all flat... if I try to something else that isnt so flat... like a whole valve cover that is FAR from flat... how the heck do I go about that? |
Hmmm... maybe I dont have an orbital sander.
If the surface is flat.. no problem. Maybe I need a bench top buffing wheel? |
palm sanders are great .. but you need to get down and dirty with some greaseless or hand sanding to make it shine.... 80 is to harsh ... rebead it with #8 or 10 wet sand it then polishing it you should be ok from there .. but that auto wax is not good for what you are doing ... buy a started kit and you will love it
