I'd like to get a variable speed electric die grinder with a 1/4" collet. I have pnuematic one, and it works great. The Dremel just isn't stout enogh some times. Plus I have a few felt bobs that are 1/4" shanks. Anyone have any experience with something like this? Thanks.
Steve |
Yes the Foredom would be great. Might have to check on an easy payment plan down at Lowes though, that's a little steep for me right now. And I agree, I don't think I'd waste my time and money on anything else. Guess I'll stick with the Dremel and a die grinder for now. Later on.
Steve |
But you would need to get a compressor that will hold a good bit of air and run it around 75-90 psi .. |
I borrowed a 1/4" drive Dewalt drill from work that turns 4000 RPM and it's been working great. I just have to be careful not to hit the chuck up against the work piece. I'm using felt bobs w/emery and it's creating "lines" in the aluminum. How do I go about getting them out? Should I use another bob with another compound? The bobs are getting the glazed look on them, do they need to be cleaned or should I get another one? Thanks. Later on.
Steve |
hey steve the trick on the chuck is to wrap it in duct tape. as for the bobs leaving lines it should work out on the next coumpound. and the glazing is just like the wheels, they need to be cleaned from time to time. i use a straight screwdriver blade(gently) or they will shred.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Steve,
I clean my felt bobs by laying a piece of 80 grit sandpaper on my work bench and running the bob over it. I also use the same 80 grit sandpaper to shape the bob to get into those hard to get into places. John Post edited due to violation of the Terms of Use http://www.caswellplating.com/bbs/viewtopic.php?t=1482 |
| advice on oven propane or electric | RCC | Powder Coating Questions | 13 | 11-26-2006 09:57 PM |
| die grinder...right angle or straight | turbohardtop | Metal Polishing Questions | 4 | 08-25-2005 09:44 AM |
| DIY electric oven question | LeeParsons | Powder Coating Questions | 1 | 07-04-2005 09:09 AM |
| will my bench grinder pull out enough power? | gopedhead | Metal Polishing Questions | 54 | 02-04-2004 12:21 AM |
| Modding a bench grinder, would this work? | berad001 | Metal Polishing Questions | 2 | 01-06-2004 07:45 PM |
