Project: 20 year old automotive alternator.
I have followed the proper procedure in bringing the aluminum to the final polishing stage, white compound. I polished with the white compound and can still see stains below the polished aluminum. There like a brownish color. I am using a loose 10" wheel for the final buffing. How do I get the stains out prior to doing a final buffing? Jrow |
I started with 150 grit sandpaper, then went to 220, 320, and 600 grit wet and dry. Wet sanded it, and then went to sisel/emery. I then proceded to polish all the way up to tripoly/spiral. Found the brown spots and started again sanding with 220 grit ETC.
No pic's John |
ARE THE BROWN STREAKS LEFT THERE FROM THE POLISHING COMPOUNDS? IF SO, YOU NEED TO GET MORE HEAT IN IT WHEN YOUR BUFFING, SOMETIMES YOU MAY NEED TO PREHEAT THE PART TO 150 AND KEEP REHEATING IT AS NEEDED. MOVE SLOWER WITH THE WHEEL TO KEEP THE HEAT IN THE PART AND USE LESS COMPOUND APPLIED MORE OFTEN. A SISAL IS PRETTY AGGRESSIVE FOR ALUMINUM, TRY USING EMORY ON A SPIRAL SEWN.
Guess there's a chance it's just a bad piece of metal with contaminates in it. |
I was wondering if it is some kind of chemical stain? I tried using some aluminum cleaner that they use on aircraft. You mix it with water. I may try to mix it a little stronger to see if that will remove the stains.
Anyone got any ideas on a product that will remove chemical stains? John |
I have heard of a set of aluminum S&S engine cases turning brownish/gold color but I forget what they decided caused it. |
| why brown before white polishing aluminum? PRO'S PLEASE READ | insomniac71 | Metal Polishing Questions | 9 | 05-24-2008 01:08 PM |
| brown compound | clockman | Metal Polishing Questions | 7 | 07-08-2005 03:57 AM |
| Brown & White don't work | kenykirschstein | Metal Polishing Questions | 7 | 04-08-2004 02:07 AM |
| black and brown bars???? | cgworth | Metal Polishing Questions | 4 | 03-24-2004 11:15 AM |
| Removing stains in aluminum | mvallee | Metal Polishing Questions | 7 | 12-04-2003 10:20 PM |
