Old 07-24-2005, 10:33 AM
Default Expander Sanding Wheels.
I've got a pretty good sized polishing project to do and I was wondering if anyone has had any experience with the Expander Sanding Wheels?
Do they gouge if used properly?
Any tips would be greatly appreciated.
John
Old 07-24-2005, 03:18 PM
pickleboy's Avatar
jrow
from all i have read here they work good and only gouge if you get to aggressive with the pressure. the problem i have is my machines both spin at 3600 rpm so i have not been able to try one yet. i think the recommended max is around 2400. i also heard that they are best on flat work without a lot of contours. hope this helps
best of luck bro
cliff
Old 07-25-2005, 11:10 AM
Thanks Phil,
I have four bumper guards from a 1952 S.I.A.T.A. to polish and they are in relatively bad shape. The sides are pretty flat so I think i'll give it a go. The only problem I can see is that the leading edges are deeply gouged, I may have to find a way to fill them so I don't change the profile to much.
John
Need Help Polishing aluminum Wheels. mattyp Metal Polishing Questions 13 06-14-2004 08:44 PM
Cant get compound onto the wheels 1105 Metal Polishing Questions 3 04-28-2004 09:05 AM
Where to buy buffing wheels Holmespolish Metal Polishing Questions 0 04-02-2004 12:52 PM
Polishing truck wheels with minor corrosion karter03 Metal Polishing Questions 0 02-19-2004 03:04 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
