Thanks for everyones help !! JHF |
the sand cast process on the compressor housing make it so rough. I tired it sand it down by hand with 160 grit but I gave up since it was going so slow. What tool do you start with? Should i pick up a die grinder? I do have a dremel with a flexshaft on it. Thanks.
for real rough castings i recommend a die grinder with flap wheel first to knock down the real rough stuff then with the same tool move to bobs and greaseless. always work from the tightest spot to the open area. i do this so i dont get discouraged when the tights take a while. best of luck bro and keep us posted on the progress.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
I am about to pick up an air die grinder. Is 90 degree angle die grinder necessary? or do you guys like the straight die grinder better? I hope to get some pieces polish so I can post picture of my engine bay. I am prettying up an 830rwhp car. Thanks.
