Old 07-26-2005, 02:16 PM
JHFGSX9D
Default How does everyone do it ?
Ok guys i really need to know how you all sand and polish extremely tight areas? i have been having trouble figuring out how to do it ?? here are some examples of the areas i cant get to
what do you use throw it out there im curious what everyone does to speed thier times up.
JHF
Old 07-26-2005, 06:09 PM
pickleboy's Avatar
jhf
i personally use cartridge wheels and cratex in a dremel tool and cartridge wheels and felt bobs w/greaseless in a die grinder. lots of patience is also required to get the show shine.
also be aware that if this cast alum. you may possibly run in to pitting. if its there its unavoidable that you will not get it completely smooth. at that point you may have to decide to plate or powdercoat. best of luck bro.
cliff
Old 07-27-2005, 11:04 AM
JHF,
I echo what pickle boy stated.
I just polished a Garrett T3 compressor housing. I was able to find 3/16" cartridge rolls that fit a 1/8" mandrel, for my die grinder. They are a 240 grit. That will get you into the slots. Check with Caswell, they may have them. I started with 220 grit cartridge rolls and went to 320 grit cartridge rolls to get the mold marks off. You will have to sand the compressor proceeding all the way up to 1000 grit sandpaper. I wet sanded mine it seemed to go faster. The names and numbers are tough to get around, but it can be done, or you can sand them off!
I used a sisal buff with emery to start the buffing (that's about the toughest aluminum I've run into). The slots can be polished with mini felt buffs on a dremel. It took me a good month to get it to look really good.
This will probably be one of the toughest buffing jobs you will do, keep with it. Good luck.
John
Old 07-27-2005, 11:45 AM
customandsound
Guest
Posts: n/a
i glass bead with #8 at 50 psi in the tite sections then i use a bob or a facer with emery to finish them off and the rest i do my regular prep and polish ...
Old 07-28-2005, 11:51 AM
JHFGSX9D
Ok guys, i have found that there is a 1 inch spiral sewn wheel available for my dremel, so i have been using that with greaseless compounds and im getting good results. Now my problem is this, im working on that FRH manifold that you see in the bottom picture and im haveing a hell of a time sanding the flat spot down in between those runners ?? any suggestions on what to do there ? i have used my wits end and cant thing of anything else to use please help !!
Old 07-28-2005, 12:32 PM
flat wooden block with sandpaper, keeps the waves out
Old 07-28-2005, 12:38 PM
JHFGSX9D
never thought about that !!
Thanks,
John
  #8 (permalink)
Old 07-28-2005, 02:01 PM
customandsound
Guest
Posts: n/a
Greaseless compound
http://www.caswellplating.com/buffs/buffing.htm
and bobs
  #9 (permalink)
Old 07-28-2005, 02:15 PM
JHFGSX9D
Originally Posted by customandsound
Custom,
Ok help me out here... I have a dremel that i have a bullet bob for it, I have been using greaseless for about 2 years now and have great luck with it. Whenever i try to use the greaseless on my bullet bob for my dremel is just flakes off it doesnt provide any cutting action at all. I allow plenty of adequate time for it to dry on the bob but no luck HELP !!
  #10 (permalink)
Old 07-28-2005, 02:17 PM
JHFGSX9D
Do you happen to have an AIM name, or a phone number where i could maybe call and ask you a few questions that are hard to explain over a forum? or if you feel better about it give me a call instead of posting your number ?
502-664-7568
