Old 08-19-2005, 06:20 PM
rides20's Avatar
rides20
Default First time with greaseless!
Well, I finally got around to buying some greaseless, and I was kinda p.o'ed about it at first. I was using a cylindrical firm felt bob and it really didn't seem to have the "cut" that I was expecting, so I just kept trying. After reloading the bob 4 or 5 times, i found that not only did it last longer, but it seemed to cut better...SWEET!!!!!! it was getting late so after reloading a few more times, i decided to call it a night. Is there anything in particular that I need to look for (besides patience?)......Keep Shinin'...Dave S.
WWW.DSMETALPROJECTS.COM
Polishing and Motocycle customization
Old 08-19-2005, 07:04 PM
fly fly is offline
Default Re: First time with greaseless!
If you can get the part to a buffer and use different wheels and compounds it will help with the speed. My preference is the black/ sisal then brown/loose and even white/cotton. If you start with a good grinding before you start polishing is also a must, but I like flapper wheels and 3M disk. Sometimes you can start with a fine glass or sand in a sand blaster before you start grinding, but the most part is a lot of patience.
Is greaseless cheating? Plus a ? berad001 Metal Polishing Questions 7 06-14-2005 02:05 PM
Another newbie - surface area to anodizing time? kumaichi Anodizing Questions 9 11-07-2004 03:46 PM
distilled vs. tap water and anodize time too short blackcote Anodizing Questions 20 07-12-2004 05:44 PM
Anodizing tank time usao Anodizing Questions 12 03-27-2004 03:06 PM
Color depth vs. anodizing time NeoMoses Anodizing Questions 17 02-03-2004 09:06 PM
