I have been sanding raw mill stainless,with 120 resindiscs,on a 6000 rpm grinder ,,then going to da sander & going from 120 up to 400grit,,disc sanding. And when I go to polish it,,,it shines nice,,but I have major waves and arcs from the grinder,,,any suggestions
We Dazzle With Brilliance |
berndog,
Are you saying that you have marks left from your sanding OR is the SS just wavy? If you have marks left from your sanding then you will have to use a finer grit paper IE 600 - 1000 grit to get them out. If the metal is wavy from manufacturing then again you will have to sand it down to get it smooth! John |
BTW, when you're done are there _any_ scratches visible under strong lighting? |
