It will bead blast the part. Bead blasting results in a satin, matte finish. Bead blasting quickly removes rust, paint etc. without being as abrasive as sand blasting or sanding.
Yes i understand that the finish will look the way that you described. Although on the website they had aluminum oxide in different grits as well as sand, glass bead, etc...so i was wondering if i ran the aluminum oxide through it not the glass bead etc. would it take down the casting pimples?
http://hometown.aol.ca/oreosly/index.html
Check out my site, in particular, the gallery on media blasting as there is a BMW rim I blasted with aluminum oxide and glass bead. Although aluminum oxide (#6 used) is much coarser than glass bead it will not remove dimples or rough cast. It is great for removing paint, rust etc on items you do not want polish ie. bike frame etc. as it will increase your sanding/finishing time. Magnaart |
| sand blasting cabinet...relocated to tips n tricks section | duke | Powder Coating Questions | 15 | 12-30-2007 11:28 AM |
| Greaseless or Abrasive Wheels? | mrtace | Metal Polishing Questions | 9 | 07-19-2005 04:42 PM |
| Converting a syphon media cabinet to a pressure cabinet? | trsick | Powder Coating Questions | 3 | 03-22-2005 08:41 PM |
| What material for cabinet building | BryanD | Electroplating Questions | 1 | 10-18-2003 01:04 PM |
| Poly Abrasive. | tomg552001 | Other Metal Finishing Questions | 0 | 08-16-2003 02:21 PM |
