Old 11-18-2002, 09:52 PM
fosgate99
Default Ok i have been using the britex wheel and i have a ?
I am attempting to recondition a brushed aluminum car rim. I stripped the clearcoat and with the britex wheel set at 1000rpms very lightly cleaned the face of the wheel. It was making a black residue wich i assume was the dirt buildup? Anyway when the wheel was done it was perfectly clean but it was duller than the other rims wich were not done yet and the surface was scratched. Shouldl i now be using white polish and a spiral? Will it be brighter when i clear it?
Old 11-19-2002, 12:00 AM
mcaswell's Avatar
Caswell Inc Founder
Hmmm, that sounds exactly what a brushed aluminum finish should look like.
Have A Web Site?
Old 11-19-2002, 08:01 AM
fosgate99
well the finish is definitly scratched. I was able to degrease the wheel and shine it up. Should i try the white?
Old 11-20-2002, 11:43 AM
mcaswell's Avatar
Caswell Inc Founder
Not if you want a brushed aluminum look, no.
Buffing it will remove the scratches (the brushed look).
Have A Web Site?
Old 11-20-2002, 12:03 PM
saiyan7
Default you are talking about two different finishes
The term brushed aluminum finish is used very loosely when it comes to car rims. The original finish on the rim is normally a milled finish that was created with a huge machine. the machine would leave scratches the were an exact size, in an exact direction, and only a couple of microns deep. You will not be able to reproduce this finish no matter what you do. The only true brushed finish I have ever seen has been on plumbing fixtures. The imperfect finish is what those type of manufacturers are looking for. I hope this helps. I have been trying to reproduce a milled finish on a set of old Saab wheels for a while now, but to no avail. Post some pics so we can see what you came up with.
Old 11-20-2002, 02:04 PM
fosgate99
saiyan i am not trying to create the brushed finish. I am just cleaning it. When i hit it with the britex it cleaned it but scratched it at the same time.
Old 11-20-2002, 03:47 PM
saiyan7
Default brightener
Caswell can you suggest a cleaner that merely bightens up old aluminum (light oxidation, dirt, grime, whatever). I think old typhoon and I are in the same boat when it comes to making old wheels look new with out polishing.
  #8 (permalink)
Old 12-29-2002, 11:01 PM
marsfrogie
Send a message via AIM to marsfrogie
Try using S&N Products Aluminum brightener. It is used mostly for machined aluminum wheels and aluminum boat pontoons and such. All you have to do is dilute it about 10:1 with water and brush it on. Then rinse clean.
  #9 (permalink)
Old 12-29-2002, 11:24 PM
fosgate99
thanks for the tip! Do you know their website? I just typed in s&n and nothing came up.
  #10 (permalink)
Old 12-30-2002, 07:10 PM
marsfrogie
Sorry, don't know of a website. I buy mine at the local parts store. I am relatively sure that they sponser Nascar driver #192.
Wheel out of balance Trixxr Metal Polishing Questions 6 06-15-2005 05:27 AM
Sisal wheel question gmascolo51 Metal Polishing Questions 3 04-04-2005 12:06 PM
Final Scratches from buffing wheel regulator Metal Polishing Questions 2 01-07-2005 12:03 AM
"optimal" wheel speeds skiddz Metal Polishing Questions 0 01-27-2004 03:29 PM
motorcycle wheel polishing...the whole wheel maddness Metal Polishing Questions 2 01-13-2003 12:37 PM
