Newbie here. I am using 2"Copper pipes for desk legs. I sanded these pipes to remove stamping from manufacturer.... now I have lost the warm sheen (coating?) that the pipes had. The result is not the warm and bright Copper that I had envisioned, but a much lighter tone. Polish has no effect. How can I regain the warm bighteness of the copper coating?
newbie310,
You polish them with a buffing wheels and different buffing compounds. Then you clearcoat them to keep them from tarnishing! If they have scratches in them then you will have to sand them with progressively finer sandpaper and then buff. Start with 320 grit wet and dry paper, and then go finer. Copper is soft so I'd start with an airway or sewn buff and some tripoli. Then finish with a loose buff and some white compound. If you don't have a buffing machine you can use an electric drill motor and 4" buffs. John |
Sorry to be vague, I don't know the correct terminology. The copper piping you would purchase at a plumbing supply store is a warmer color,(burnished?) whereas my sanding and polish has left it a lighter color.
Do you know what chemical I can get to treat it? |
Edit: Caswell Inc. sell these products at http://www.caswellplating.com/kits/metal.htm Last edited by mcaswell; 01-21-2006 at 09:02 PM. |
| "Sandwiching" Acid Copper | AresP | Electroplating Questions | 1 | 08-27-2004 08:19 PM |
| Please explain "cure schedule" and smoked/black ch | BlindUmpire | Powder Coating Questions | 5 | 05-11-2004 02:38 PM |
| "Radio Shack Current Sense Resistor" | jtsuttle | Anodizing Questions | 3 | 04-14-2004 09:25 PM |
| "Hard" Anodizing vs. "normal"; differenc | dagobert | Anodizing Questions | 6 | 02-26-2004 11:24 PM |
| practice pieces of copper pipe | bhhodges | Electroplating Questions | 0 | 02-07-2004 07:28 PM |
