if its aluminum(probably) it may be anodized. if so try spraying it down heavy with easy off oven cleaner and see what happens. if it is ano it will be removed if not you are only out a few bucks and some more time.
when in doubt polish it out/ why replace it when you can refinish it G2 Polishing and Powdercoating |
Have you have tried the aircraft stripper? It has always worked for me. Sometimes it will take multiple applications. If you are sanding, you need to drop to a 180 grit. Another option would be to have it beaded.
SS |
You can get aircraft stripper at most auto parts or big box stores. If it is anodize, you can use Easy Off oven cleaner like Pickle said. Anodize can be removed by anything acidic or base. SS
Cantex, Aircraft remover or "stripper" will not strip anodizing off of aluminum. The anodizong process is not really a coating at all, it is a process that actually colors the surface of the aluminum and "seals it" making a very durable barrier. To remove this, the best way is either doing what pickle said and deal with the fumes, OR use sodium hydroxide mixed with distilled water. BE CAREFUL USING THIS!!!! you can ruin the part if it is soaked too long. You can check to see if the part is anodized using a DMM (multimeter). Set it to continuity (the beep)...and hold the leads to the part. Anodizing is actually an insulator, and you should not hear a beep. After the part is soaked (you will see some discoloration) you should hear a beep if the coating is removed! Have fun and good luck! Do a search on flea bay for sodium hyroxide
dude, thats exactly this info i was loooking for.
the part did go a milky color after i used easy off ( i had some at home) but still didnt remove all the anodizing. i will try the sodium hydroxide, or else you may be getting a part to polish.... |
| MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! | NautiShine | Metal Polishing Questions | 61 | 05-15-2008 02:03 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| input on aluminum polishing and need help choosing a buffer | Sid03 | Metal Polishing Questions | 7 | 08-09-2004 10:21 AM |
| Aluminum polishing - What wheels/compound do I use? | 63Jag | Metal Polishing Questions | 2 | 12-08-2003 11:12 PM |
| Polishing Aluminum (Engine intake) | RyanT | Metal Polishing Questions | 3 | 02-25-2003 07:53 PM |
