Old 01-23-2006, 10:48 PM
Tire_Shredder is on a distinguished road
Default Greasless compound with used wheels?
Hi Guys,
I've polished a set of aluminum wheels before using caswell products with good results aswell as a powersteering reservoir and some other things and becoming slowly addicted. I clearcoated them aswell and still look great a year later after daily driving! my next project is my cast aluminum intake manifold on my fuel injected car. To try and speed up the process a little bit this time, and to keep the round surface uniform, i've decided to give greasless compounds a shot and sand up to 1500 grit like I did on my other projects. I have plenty of extra spiral sewn wheels left over that are still in good shape which I did not use fully due to contamination in initial trials. for instance, I have at least two spiral sewns (I'll only be using my new loose cottons and white compound for this) which have black compound on them from before. Is it possible for me to re-use this buff and loading it up with greasless without any ill effects? of course I know to use one wheel for one compound but this won't be used for black anymore and might aswell be thrown out if it's not of use. Can I use wheels which have buffing compound on them for greasless without causing any problems?
Thanks, Steve
Old 01-24-2006, 06:50 AM
Default Re: Greasless compound with used wheels?
Originally Posted by Tire_Shredder
Hi Guys,
Thanks, Steve
Only problem I see is possibly the greaseless won't stick to the wheel as well. Rake the hell out of the wheel first. Or possibly trim the outer surface with shears, but I wouldn't think that would be necessary.
Old 01-24-2006, 12:20 PM
pickleboy's Avatar
as mpierich said it should be fine. i have done just that before. i had some old 6" wheels that were run to about 4.5", no good for the motor anymore, i use them on my electric hand grinder with greaseless and it is fine. like mike said you will need to rake them clean.
What blasting media? mpierich Metal Polishing Questions 21 08-30-2005 09:30 AM
3M Liquid Glaze Compound with Flannel Wheels? vaudouu Other Metal Finishing Questions 4 06-11-2005 12:53 AM
problems polishing aluminium alloy with white compound rotorman Metal Polishing Questions 6 08-02-2004 12:57 PM
Cant get compound onto the wheels 1105 Metal Polishing Questions 3 04-28-2004 09:05 AM
greasless compound spydersac Metal Polishing Questions 1 08-15-2003 01:13 PM
