I started working on my wheels. I have wetsanded to 600 grit, and I had a very even finish. So I started working with the black compound and a 4" spiral sewn wheel with my drill (running at 3100 rpms). Now I'm getting alot of uneven scratches and swirl marks. Is this normal? Do I use only cutting motions with the black, or should I do both cut and colour motions? Will these swirls come out? Or will I have to go back and wetsand at 800 grit? Keep in mind that I'm not done with the black, I have to even out the finish some more. Thanks for your help!
ChrisVW,
Your going in the right direction. You should try to buff in one direction then change directions to 90 degrees from the original way you buffed. The temperature and pressure are your best friend. When the aliminum reaches the right temperature it will take the swirls out. DON'T keep your buff on one spot to long as you will burn the aluminum, just keep it moving. I guess you could call that the "sweet spot", when the heat and pressure applied to the metal will start to make it shine. You'll know when you get there. The sisal/emery will leave swirl marks but you will see a shine, they will be finer than the 600 grit sanding. When you reach that spot its time to change to a sewn buff and either Stainless of Tripoli buffing compound, then to loose and white compound. Keep us posted. John |
| Serious Help Needed, Polishing aluminum valve cover. | m3the01 | Metal Polishing Questions | 29 | 01-28-2008 11:57 AM |
| Stainless Steel Polishing Needed | mross | Metal Polishing Questions | 3 | 09-15-2005 08:39 AM |
| Stainless Steel Polishing Needed | mross | Services Offered/Wanted | 0 | 09-14-2005 12:17 PM |
| aluminum polishing needed | toxicd | Services Offered/Wanted | 1 | 08-21-2005 02:10 PM |
| motorcycle wheel polishing...the whole wheel | maddness | Metal Polishing Questions | 2 | 01-13-2003 11:37 AM |
