I have a problem that is driving me crazy. I'm polishing a cast aluminum motorcycle clutch cover, for an old Ducati. There seems to be an irregularity in the structure of the metal itself: some small areas are harder than others. It's as if when it was cast, the alloy wasn't consistent. This is apparent even when sanding the metal: there's a pattern that shows up.
When polishing with a 3/4 hp buffer, 8" spiral wheel, and black compound, this results in smeary-looking ripples and other irregularities. This is only true in two places on the cover; the rest is polishing up nicely. I have a Dynabrade hand-held belt sander, and I'm going to try using non-woven conditioning belts to try to even out the surface better. Any other hints or suggestions? |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Polishing cast aluminum | turbohardtop | Metal Polishing Questions | 26 | 07-05-2005 10:10 AM |
| Cast Aluminum | scocklin | Anodizing Questions | 5 | 12-03-2004 11:38 PM |
| copy chrome and aluminum problems | jtagger19 | Electroplating Questions | 1 | 08-14-2004 06:15 AM |
| Cast Aluminum polishing? | Neons4life | Metal Polishing Questions | 4 | 02-01-2004 02:45 PM |
