Old 02-05-2006, 04:14 PM
BigSilk22 is on a distinguished road
Default Polishing motorcycle pegs
Does anyone know the easiest way to sand motorcycle pegs? In particular the rigid part for the sole of the shoe to keep from slipping. there appears to be some gry type of paint or coating, will paint remover take this off?
When I sand the pegs I can't seem to get in between only the high points.
any help will be greatly appreciated.
Old 02-05-2006, 04:43 PM
fly fly is offline
Default Re: Polishing motorcycle pegs
Since I don't quite know how the peg looks, just me thinking I would use Black compound with Sisal wheel, this will remove regular paint and should take the metal down to what you need for your final step.
Old 02-05-2006, 05:14 PM
sswee's Avatar
Moderator
On that style of peg, I bead blast to get the recesses clean and to bare metal. There are some wheels similar to a wire wheel but the bristles have a abrasive coating. SS
Old 02-07-2006, 01:50 AM
rides20's Avatar
rides20
If it's a modern sportbike, it's anodized....use sodium hydroxide to stip it, then go right at it with brown on a vented flap disc..then white on loose and BLLLIIINGGGGGGGGGGGGGGGGGGGGGGGGG! Dont worry about sanding them, the grooves arent too deep for the wheels!
WWW.DSMETALPROJECTS.COM
Polishing and Motocycle customization
Old 02-07-2006, 06:01 PM
Can I get the Sodium Hydroxide at a lowes or home depot kind of place?
Old 02-07-2006, 06:08 PM
pickleboy's Avatar
sodium hydroxide is lye it can be found in easy off oven cleaner it works well for anodizing removal. just get a can and shoot a heavy coat, let sit for half an hour then rinse off. you will be able to see a difference in the color of the pegs if it is anodized.
Old 02-07-2006, 09:14 PM
fly fly is offline
I polish those same type of pegs all the time and all I do is just polish them and then plate. THe polish will remove what you need and polish at the same time. Black with sisal wheel or a yellow vent wheel.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 03:03 PM
Polishing cast aluminum motorcycle engine cases. Mutt Metal Polishing Questions 1 07-17-2005 12:46 AM
motorcycle polishing questions shaybirde Metal Polishing Questions 3 04-30-2005 02:56 PM
NAUTICAL METAL AND MOTORCYCLE POLISHING IN FLORIDA! NautiShine Services Offered/Wanted 5 06-08-2004 08:21 AM
Polishing aluminum motorcycle wheels emprcyrul Metal Polishing Questions 7 02-15-2003 11:28 AM
