Old 02-10-2006, 06:50 AM
jcole113 is on a distinguished road
Question new at polishing...PLEASE help!!
i have a CBR im trying to polish out. so far i have stripped all the anondizing off the frame, subframe and swingarm. i then started sanding by hand like there was no tomorrow using these grits: 220, 320, 400, 600, 800, 1000, 1200, 1500, 2000, 3000. from 400 grit and higher i wet sanded it, going only in one direction. took forever and my arms are dead but all the aluminum is smooth as can be. is this improper? ive been reading some posts on here and people say to stop at 600 and use the compounds..? i havent ever used compounds, and none of my buddies have either. i know of 2 people where i live that polished their bikes, and they just sanded up to 2,000 grit then used Mother's polish. but their shine isnt as good as some of the pictures ive been seeing on here. please someone guide me in the right direction. should i go back down to 600 and use some combo of compounds? if so, what compounds should i get w/ what wheels? i read to possibly use a losse cotton wheel with white liquid.? or should i just use some aluminum polish on the 3000 grit and hope for the best? sorry if i come off as improper, but i am extremely ignorant in the field of polishing aluminum. any help is appreciated!
Old 02-10-2006, 06:59 AM
Default Re: new at polishing...PLEASE help!!
sorry for the typo *Loose cotton wheel
also i do have flitz liquid polish and the flitz polishing ball but i havent applied any to the frame. again, any help is greatly appreciated.
Old 02-10-2006, 07:05 AM
fly fly is offline
do you have any buffing wheels like what you see on the caswell site? You really need this adapter. http://www.caswellplating.com/buffs/grinderadapter.html
Old 02-10-2006, 03:23 PM
as of now, i dont have any wheels or compounds. im trying to figure out if i should buy them or just stick with the frame at 3,000 grit and put on some aluminum polish (flitz).
Old 02-10-2006, 03:24 PM
rides20's Avatar
rides20
You're all good with the sanding part...the finer you sand..the finer the finish will be! After all of that sanding is done, use brown Tripoli compound on a vented flap disc GO IN ONE DIRECTION...then when that's done, wash it down well with dish soap and warm water...dry everything, and hit it with white compound on a loose wheel again, going in one direction (this mimimizes the effects of reflected light showing scratches) wash it again and if need be hit it with some of caswell's liquid white rouge..you should get what you are lokoing for after that!
WWW.DSMETALPROJECTS.COM
Polishing and Motocycle customization
Old 02-10-2006, 03:36 PM
can i get the vented flap disc from caswells? also, if i needed the liquid white rouge, what should i use to apply that..another wheel or by hand..? thanks for the help so far.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 03:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Dimensional influences of Brite Dip Polishing Aluminium whistule Metal Polishing Questions 0 10-03-2003 09:40 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 09:12 AM
Intake Manifold Polishing Dino6961 Metal Polishing Questions 2 09-05-2002 01:47 AM
