what do you guys use to clean in between greaseless and polishing compounds? i accidentally use Easy Off oven cleaner and it totally messed up areas i couldn't buff out...
Any recommendations? Is Simple Green okay? |
if possible heat the bath up made of soap and it will help or purchase the SP degreaser from caswell and heat it up, when you heat the bath it helps get into those hard to get areas...
www.chrome-plater.blogspot.com |
Yea I like simple green just about anywhere even in the washing machine
[Umm removed
Yeah, a bunch of were talking about it in an airplane forum. I used to use it a lot, and some guy came on and said that it caused corrosion, and we blew him off as a troublemaker. But I wondered about it, and so I took some strips of 2024 alclad (pure aluminum clad) and immersed them in the stuff. I was amazed at how bad it turned the surface.
After a month sitting in the stuff, several thousanths of the surface was gone! And the piece went from black to grey. BUt like I said, if you get it off fast, it might be OK. No one soaks anything in the stuff, but it's nice to know. |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 08:37 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| simple green...... | Sid03 | Anodizing Questions | 3 | 03-18-2005 01:19 AM |
| Degreaser - Simple Green? | kickn | Anodizing Questions | 1 | 09-22-2004 09:50 PM |
| HELP! White haze when degreasing polished aluminum! | davidh90046 | Metal Polishing Questions | 2 | 10-15-2002 02:19 PM |
