i was talking about plastic pieces on bike, just a reagular frame for a gsxr 1000 and a few little pieces, pesgs, brakets, so on, just wondering effects VHT on plastic and how much would be used? i think 5 cans is ALOT of finish but i am only an expert at paint new to the polishing game...thanx
COLLYNFACE4603,
It sounds to me like your polishing your frame with the engine and all accessories on it? If that is the case you will need to protect all the surfaces that you don't want the clear spray on! I don't know what the clear spray would do to the existing finish of the surounding parts! It's a nitrocellulose lacquer and may damage the other finished surfaces! Try this link and it will give you a description of nitrocellulose lacquer. http://en.wikipedia.org/wiki/Lacquer John Last edited by jrow; 02-22-2006 at 12:10 PM. |
i would have to say if you are going to clear coat it you will need around 5 cans. that's if you are polishing your sub-frame also. i would not recommend that you let over sray get on any of your body work or sorounding areas. the best way would be to strip your bike down to the frame, polish it and before clear coating it, tape anything off that you are not trying to clear coat.....
mcaswell in one of your reply post you said (.I'd prefer VHT Clear Lacquer, not the Hi-temp.)I look at your store would you have a number for the product don't want to order the wrong thing .I polished my forks on my motorcycle about every month, repolish, I tried flitz and mothers I would like to try and spray seal them.i know I would probably loose a little shine but i will sacrifice this for so much labor thanks for your time.And i really don't care for zoopseal.All my aluminum on my bike was sanded down and polish with compounds and then with flitz and sometimes mothers still get oxidation.
| Golf Clubs - How to remove nickel finish prior to refinishin | doctordave | Other Metal Finishing Questions | 3 | 06-03-2005 03:21 PM |
| Newbie, trying to find best way to finish aluminum-LONG POST | chik | Metal Polishing Questions | 6 | 03-14-2005 08:11 PM |
| wavy finish | mike82 | Powder Coating Questions | 9 | 02-24-2005 07:44 PM |
| can we identify this finish? | funkmunky | Electroplating Questions | 3 | 12-15-2004 08:45 PM |
| Sealing | RPE | Anodizing Questions | 1 | 04-08-2004 02:39 AM |
