First off here's what I've done so far.
palm sanded to 220 grit (can find finer hook and loop around here) wetsand to 600 grit. 4" sprial sewn with emery 4" sprial sewn with tripoli 4" loose cotton with white I'm doing all this with an electric drill with a max speed of 3100 rpms. I've tried to go in one direction, then switch 90 degrees. I've also tried to use both cut and colour motions with the drill. I've looked back at my pictures after finishing with the emery, and my finished product (white) still has the same scratches as after the emery. Pickle suggested before that I wasn't using the correct heat/pressure, and to rake more often. I tried to do this but I'm still not getting results. When viewed at an angle the wheel looks great, but when looking at it straight on it's very hazy and full of scratches. Should I got back to the emery and spiral? Is the equipment I'm using going to cut it? or do I need something faster? Please help! ![]()
_If_ you did every previous step completely, and the scratches were indeed left by the emery, you could try tripoli (brown) before the white.
I find that the scratches are often left by a previous step not completed...I force myself to keep going for quite a while after I think a step is done, just to make sure. I hate to say this, but I've learned that sometimes you have to backtrack and start over at one of the previous steps, maybe even down to the 2nd one. Keep track of which step you did in which direction, it can give you clues as to where the scratches came from. |
| More Wheel Polishing help needed! | ChrisVW | Metal Polishing Questions | 2 | 01-25-2006 08:39 PM |
| polishing 6061 aluminum w/bad results | clockman | Metal Polishing Questions | 6 | 05-16-2004 05:41 PM |
| Bad Polishing Results | kenykirschstein | Metal Polishing Questions | 4 | 01-08-2004 05:27 PM |
| motorcycle wheel polishing...the whole wheel | maddness | Metal Polishing Questions | 2 | 01-13-2003 11:37 AM |
| Magnesium wheel polishing or??? | 2ndGenSurfer | Metal Polishing Questions | 0 | 03-30-2002 03:40 AM |
