Old 03-02-2006, 01:31 PM
rwh rwh is offline
rwh is on a distinguished road
Default Buffing
Howdy guys, this is my first post, so be gentle. I'm looking to spruce up my aluminum rims that are in excellent shape but have VERY minor surface scratches. Just looking to go to the next level so to speak. I have surfed around somewhat and I'm assuming the white compound with a canton flannel wheel is the ticket. I'm a big time novice and I've been looking for a flexable attachement I can use on a drill. Does Caswell carry this. I may have missed it on the web site. I have seen the Red & Blue compound also, is this something worth using for my above mentioned project? Oh yea, just to clarify, the rims are not clear coated, just polished alum.
Thanks,
Randy
Old 03-02-2006, 01:50 PM
Default Re: Buffing
You might want to start with white/canton to see what it does, then if that's too mild work backward to white/spiral. The type wheel has as much to do with the finish as the compound.
Once you get the scratches out, the red will really make them showy. The blue is really mild - in fact it's used for plastic a lot.
Why use a flex shaft with a drill? - just use the drill. Do not use cheap flex shafts - they won't last. Caswell sells a pretty good heavy one but a drill might not be enough to power it. I use an old refrigerator motor.
Buffing wheels and their compounds. Something not right. L98-Z Metal Polishing Questions 7 01-21-2006 02:23 PM
Buffing speed question berad001 Metal Polishing Questions 3 03-11-2005 09:55 PM
Where to buy buffing wheels Holmespolish Metal Polishing Questions 0 04-02-2004 12:53 PM
Where to buy buffing wheels Holmespolish Metal Polishing Questions 0 04-02-2004 12:52 PM
buffing direction hue Metal Polishing Questions 2 02-23-2003 10:28 PM
