So I think I've got the basics. Started with 80 then 180 then 220 then 320 and now 400. My question comes back to wheels and compounds. All I have is a tight wound wheel for cutting and right now I'm using the black emory compound. Would the sisal wheel help? Would this pickup the cut? I'm assuming I will get all of the previous scratches out? Where should I go after the emory? Brown or White on the soft wheel?
Thanks Ken |
kenrinc,
Start with the sandpaper that will do the job with out leaving real deep scratches. I'd start with 180 or 220. Do a small area and then go to 320 and buff. See how it looks. If you still have scratches use 400 or 600 grit and try again. The sisal wheel with emory cuts the fastest. The sisal wheel with stainless compound would be next, ETC. The sewn wheel with emory cuts less that the sisal wheel with emory, ETC. The harder the wheel the faster the cut. Steps: Use the sewn wheel with emory then use a new sewn wheel with tripoli and then the loose wheel with white! John Last edited by jrow; 03-29-2006 at 02:54 PM. |
| why brown before white polishing aluminum? PRO'S PLEASE READ | insomniac71 | Metal Polishing Questions | 9 | 05-24-2008 02:08 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| input on aluminum polishing and need help choosing a buffer | Sid03 | Metal Polishing Questions | 7 | 08-09-2004 11:21 AM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 09:12 AM |
| Polishing aluminum chevy 350 cylinder heads | radioactive | Metal Polishing Questions | 2 | 12-04-2002 07:51 PM |
