Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 04-01-2006, 07:30 AM
hybred
Default polished. now powdercoat clear?
just finnished polishing my turbo housing for my mustang. it's the compessor side that it polished and doen't see nearly as much heat as the turbine side. i'd like to keep the finnish up without having to periodilcly rub/polish it. couple of q's about clear options. thinking of powdercoat clear as it will be a little tougher than regular clear coat. i'm a little confused here. when i buffed i used black, brown & white. dosn't that leave some of the compound IN the metal? when i powder coat and bake won't the surface bubble as the compounds in the alum come to the surface and ruin my pc job? also, a question about using clears. wouldn't spraying clear on a polished alum peice be like spraying clear on a peice that's been previously waxed? i'd appreceate any info from anyone who's done either. thanks. btw, here's a before and after
polished. now powdercoat clear?-13b-tb-2_001.jpg   polished. now powdercoat clear?-13b-tb_002.jpg
Old 04-01-2006, 07:31 AM
hybred
Smile Re: polished. now powdercoat clear?
here's how it looks now
Old 04-01-2006, 09:54 AM
hybred
Default Re: polished. now powdercoat clear?
did some more searching and will definatly stay with the pc for protection. found brake cleaner works well for "degreseing" thanks.
Old 04-01-2006, 11:03 AM
pickleboy's Avatar
looks really good bro.
Old 04-01-2006, 11:31 AM
thesound has a spectacular aura aboutthesound has a spectacular aura about
You did a nice job on that. I've sent you a PM about your coating inquiry.
Old 04-01-2006, 11:37 AM
hybred
thanks.. comming from this place it's trully a compliment .
Closed Thread
clear on polished mild steel chromeitout Powder Coating Questions 5 03-27-2006 07:40 PM
Pcing clear over polished Aluminum JeffL Powder Coating Questions 2 03-10-2006 10:32 AM
clear coating polished alum hybred Metal Polishing Questions 7 08-08-2005 03:58 PM
clear powdercoat over airbrushing? kecf Powder Coating Questions 5 01-16-2005 10:01 AM
Will clear powdercoat dull a polished finish? wozzwinkl Powder Coating Questions 3 09-22-2004 08:53 AM
