So I decided to put the vtec solenoid on hold and start on an alternator bracket, and the bracket that holds the power steering pump. I started with a sanding disc on my dremel, lightly on the top just to cut into it. Then like magic, the 220, 400, 600, 1000 went GREAT. Couldn't find 1500 at my local hardware store, so didn't worry about it. Got some black rouge to start and red to finish using felt polishing pads to on my dremel, and I got scratches. You can't see them very well on the pics (the pieces look GREAT at a distance) lol, but how can I NOT get the scratches next time? I'm still saving money so that I can get a buffer that'll last me. I don't wanna get a weak one that's cheap and end up buying another one. I'm done with that.
First off, congrats on a job well done. Those turned out nice. Second, judging by the pics but not actually being able to see the part up close in person, I'm gonna guess that the scratches you have left are buffing marks. Do the scratches only seem to show up when you can see the light reflecting off the part from tilting it at certain angles? Are the scratches totally random, going in a million directions and give off the impression of looking at an aurora borealis? If so, those would be buffing marks.
"Some people are like sandpaper: they may delight in the misery they inflict by rubbing up against you, but in the end you will come out smooth and polished while they'll just be ugly, wrinkled, and used up." - Beyonce Knowles |
I also nicked them up pretty good when the dremel slipped. DOH! Being the beginner that I am, I'm more grateful for these errors so that I know what to expect. I've read many warnings from threads about holding that dremel tight. Thanks for getting back to me. I'll get better at taking pictures of my work. Thanks for sharing. |
chefboiali,
You might want to save yourself some grief and get some 4" buffs and use a 3/8" drill motor to buff your small parts. You will have a lot more control over the 4" buffs that your will the Dremel! John |
Thanks for your suggestion about the drill. |
chefboiali,
If your balcony has a railing, I couldn't think of one that wouldn't, you can purchase a vise that will clamp to the railing and your in business! I know it's tough living in an apartment and not having a place to work. I ported and polished a head in an apartment when my wife and I were first married. What a mess. Try polishing, after you WET sand with 400 or 600 grit, it should cut your finishing time down. John |
When I sanded the alternator bracket for the second time, I we sanded down to 1000, it got smoother. I just recieved my hand sander. Little Black and decker mouse model. Got it for a good price. Can I wet sand with it? I figure when I do my valve cover, it will cut my sanding down considerably. |
| MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! | NautiShine | Metal Polishing Questions | 61 | 05-15-2008 03:03 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Dimensional influences of Brite Dip Polishing Aluminium | whistule | Metal Polishing Questions | 0 | 10-03-2003 09:40 PM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 09:12 AM |
| Tips on polishing inbetween letters and in tight corners | tomg552001 | Metal Polishing Questions | 2 | 03-13-2003 02:29 PM |
