  #31 (permalink)
Old 05-25-2006, 01:36 PM
Default Re: Polishing tight corners. New guy.
Originally Posted by pickleboy
if you cant find adhesive backed paper for your sander then i suggest (its what i use) is a can of spray glue from the craft store. it will stick the paper to the sander pad and if you only spray it on the paper lightly it is easy to peel off when worn out and is waterproof. best of luck.
I been using rubber cement for that for years, pickle. I make up a bunch of precut pieces and coat them with cement and let 'em dry (don't let the treated backs touch each other), then I put cement on the sander pad and the paper is already ready to go. I use that for small 2"-3" sanding drums too so no need to buy the made sleeves (just gotta overlap the edge a little so it doesn't catch).
  #32 (permalink)
Old 06-19-2006, 05:37 PM
psmcintosh is on a distinguished road
Originally Posted by sswee
There are dremel bits called cratex that work very well. They are rubberized with grit in them. I don't know if HD carries them, I usually get them from machine shop suppliers.
SS
I love cratex wheels, even though they're pricey. I bought a kit containing several shapes in 4 grits each on eBay as a starter, and I now buy individual wheels from b2bprofessionaltools.com to replenish the ones I use. Since I work on soft metals like aluminum and brass and usually don't need to polish out deep scratches, I use mostly the "extra fine" ones.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 03:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Dimensional influences of Brite Dip Polishing Aluminium whistule Metal Polishing Questions 0 10-03-2003 09:40 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 09:12 AM
Tips on polishing inbetween letters and in tight corners tomg552001 Metal Polishing Questions 2 03-13-2003 02:29 PM
