+ Reply to Thread
Results 1 to 5 of 5
Thread: Need Help polishing large flat section
  1. #1
    Default Need Help polishing large flat section
    I am a newbee to the site and I have been polishing aluminum for years, I have a 3/4 hp bench polisher, all different types of wheels air tools, etc. Most of my polishing I do is with a bench polisher or with my air tool grinders. Here is my problem, the part I have is on the car and would be very difficult to take it off, so I cannot take it to the wheel. It is a flat piece about 4 inches wide and 2 feet long, so it will easily show imperfection. Polishing a large flat surface is a different animal" I was thinking about some type of bonnet, like my 8" auto buffer but in a 4" for my grinder. It would have to tight weave. I know it can be done because I saw a 4 foot by 8 foot pieces of aluminum that someone used as pickup bed cover and was told they used powered hand tools. I have already sanded it smooth so it is ready for polishing. Any help would be appreciated.
    Share with Facebook
  2. #2
    Join Date
    Aug 2004
    Posts
    957
    Default Re: Need Help polishing large flat section
    There is an adaptor you can get to put regular wheels onto an angle grinder - I believe Caswell sells them - look in the polishing section. Personally I think the grinder is too fast, but some guys in here do use them and apparently like them.
    For a slower speed tool, why not use your wheels on an air drill with a mandrel? Or, you could get a flex shaft on an electric motor.
    Share with Facebook
  3. #3
    Join Date
    Aug 2003
    Posts
    82
    I'd get the surface emery smooth by whatever means you deem necessary, not worrying too much about streaks. Buffing wheels would work fine but if you're concerned about the mass of one bogging your grinder down one of these puts down a decent footprint:
    http://www.caswellplating.com/buffs/tapered.html
    Once it's emery smooth take out the streaks and finish it up with one of these:
    http://www.caswellplating.com/buffs/flball.html
    You've got 6 inches of surface area coverage to work with on one of those, which oughtta permit you to strafe your grinder in a straight line back and forth across the part while having enough overhang to avoid streaking. The only stipulation on this Flitz Ball is that it's only liquid polish friendly, so you'll either need to use some of the Flitz brand polish or you could possibly get away with using some of Caswell's Liquid White Rouge.
    Share with Facebook
  4. #4
    Thanks for the info. I am glad that I found this site.
    Share with Facebook
  5. #5
    Join Date
    Sep 2003
    Location
    Langley,B.C.
    Posts
    48
    I use an angle polisher with a 10" yellow vented wheel,,brown compound,,followed with a loose buff with either green or white compound,,,works for me
    We Dazzle With Brilliance
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. MOTORCYCLE POLISHING 101 CLASS IS IN SESSION!
    By NautiShine in forum Metal Polishing Questions
    Last Post: 05-18-2009, 01:23 PM
  2. Something for you die hard polishers out there to chew on
    By thesound in forum Metal Polishing Questions
    Last Post: 12-03-2007, 12:16 PM
  3. Frame polishing....same process...2 different finishes? HELP
    By bairdmotorcycles in forum Metal Polishing Questions
    Last Post: 06-27-2005, 03:13 PM
  4. large part finish?
    By slamed150 in forum Metal Polishing Questions
    Last Post: 07-11-2004, 10:03 PM
  5. Dimensional influences of Brite Dip Polishing Aluminium
    By whistule in forum Metal Polishing Questions
    Last Post: 10-03-2003, 08:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
