What is the best abrasive/tool to use on an air tools to smooth or remove paint in tight areas found on aluminum alloy wheels? Preferably with variable grits.
I have a method of machining the flat surface of the wheel very quickly but the interior angles are difficult to smooth and sand to a paintable surface quickly. I have buffs and polishers of different shapes but I really need a tool that can form to any shape and have variable grits avaluable (reach tight areas). Thanks for any input! |
Build a PA-Blaster and run it at about 60-psi (to be gentle on the aluminum) DONE !
Best part is you make it from JUNK ! Sorry.. not much of a salesman.. But 840 members think so..
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Stripping chrome plating from aluminum | bbqboyee | Anodizing Questions | 4 | 04-22-2006 02:22 AM |
| stripping anodizing off aluminum | broker1234 | Metal Polishing Questions | 1 | 01-16-2005 10:28 PM |
| Powder Coating Stripping from Aluminum | kaleem1 | Powder Coating Questions | 0 | 11-24-2004 03:54 PM |
| Motorcycle Aluminum Wheel Polishing | mprodrick | Metal Polishing Questions | 5 | 03-24-2003 02:24 AM |
