Ok,
So i'm mainly polishing aluminum parts for a car... (manifold, turbo housings, misc parts). So I've used a sisal wheel with black emory bar, cutting is actually pretty good, and takes out lots of the scratches. Very happy with the results this gives. My question is after I apply compound and everything gets cloudy on the metal should I stay in that position until the metal starts to polish up (clear and return to a mirror state?) When i'm satisfied with the results of the emery bar I move on to a yellow bar (which is supposed to replace a white bar) Not quite sure sine there is no info on the website but the caswell rep in canada was convinced it's better then white. I use this compound with a denium wheel and it gives a nice shine but how do I keep the rest of the metal from clouding up after applying the compound? Do I clean the material by hand after polishing with a clean rag? Should I be cleaning the item before moving on to a new compound? Finally I don't really see the use of the loose coton wheel over my denium wheel, doesn't seem to give better results? Thanks for the help!! |
Here are the sepcs on my 6" grinder (using 8" polishing discs)
Fully balanced, 1 medium and 1 coarse grinding wheel for a variety of dry applications Two heavy-duty eye shields to protect the operator from injury A gooseneck-style lamp to provide light on to the item being grounded - bulb not included Rear exhaust chutes direct debris away from operator Cast-iron base and motor housing to reduce vibration and increase stability 3.5A ball-bearing motor provides 1/2-hp for a no load speed of 3,450 rpm 14½ x 8 x 17" d (37 x 20.4 x 43.2cm d) The sepcs on my new 8" grinder is below however, they use 1/2" arms instead of 5/8th so I can't use my caswell arm extensions. I was planning on returning it beucase of that. Fully balanced, 1 medium and 1 coarse grinding wheel for a variety of dry applications Two heavy-duty eye shields to protect the operator from injury A gooseneck style lamp to provide light on to the item being grounded - bulb not included Rear exhaust chutes direct debris away from operator Cast-iron base and motor housing to reduce vibration and increase stability 5A ball-bearing motor provides 1-hp for a no load speed of 3,450 rpm 16 x 10 x 18" d (40.7 x 25.4 x 45.8cm d) |
| Looking to purchase pro type gun from caswell have questions | chicagorich | Powder Coating Questions | 10 | 03-23-2006 01:05 AM |
| Some newbie questions... | kiwijetpilot | Anodizing Questions | 16 | 03-12-2005 08:18 PM |
| Can a newbie chrome for profit witht he caswell kit | trsick | Electroplating Questions | 4 | 01-08-2005 06:52 AM |
| Newbie questions about Powder Coating | thirdlife | Powder Coating Questions | 3 | 12-16-2003 05:09 PM |
| Fumes and basic newbie questions | PeterBusch | Anodizing Questions | 7 | 10-05-2003 09:30 PM |
