Old 05-06-2006, 06:06 PM
mfergel is on a distinguished road
Default Do I need to use the Sisal wheel?
I'm doing my first aluminum polishing job....as swing arm from a Buell XB9R. I sanded it down with a palm sander to 800 grit. I'm using the sisal wheel with the black and it seems like it might be actually adding scratches.
Do I need to use it? Might I be better to go up to 1000 grit (or even higher) and just avoid using it? Or should I stick with 800 grit but maybe use the black compound on a spiral sewn wheel instead?
Old 05-06-2006, 06:53 PM
pickleboy's Avatar
Default Re: Do I need to use the Sisal wheel?
that is what i would do. if you have the right wheel speed and pressure you can get a spiral to work just fine. or you can also try using a treated vented buff and emory for even faster cutting but without the scratching of the sisal.
Old 05-06-2006, 09:03 PM
Do I need to be careful to avoid having the wheel speed too fast?
Old 05-07-2006, 04:14 AM
chromepl8tr
No. a sisal wheel is for finishing steel and stainless steel. you need to use a treated buff with a tripoli compound. then final buff with a cotton buff using chrome rouge.
Change buffing wheel for different metals? MThings Metal Polishing Questions 7 12-14-2006 07:25 PM
Wheel out of balance Trixxr Metal Polishing Questions 6 06-15-2005 04:27 AM
Sisal wheel question gmascolo51 Metal Polishing Questions 3 04-04-2005 11:06 AM
Final Scratches from buffing wheel regulator Metal Polishing Questions 2 01-06-2005 11:03 PM
Sisal Wheels rdanielewski Metal Polishing Questions 1 12-05-2002 09:37 PM
