Old 06-20-2006, 10:35 AM
bob_fickel is on a distinguished road
Default Cleaning/polishing help with lettering on rim
Any suggests/help on how I clean and polish the letters on a motorcycle rim?? I'm a newbie to metal polishing and I'm having problems removing the paint, the surface is textured.....and then the big question.... how to polish it??
here's a picture of what I'm working on
http://ca.geocities.com/bob_fickel/gsxrrim.jpg
Plz/Thkx!!
Bob
Old 06-21-2006, 11:25 AM
Default Re: Cleaning/polishing help with lettering on rim
Plz/Thkx!!
Bob
You'll probably need to be more specific...take the time to search this forum and most of your questions will be answered.
About the letters...personally I would shine them up with 320 sandpaper, spray flat black paint in there and wipe off the letters, leaving them bright on a black background. If you actually wanna polish the background, it'll probably entail many hours with a Dremel, and the risk of screwing up the letters.
Old 06-27-2006, 09:15 PM
funcheon5488 is on a distinguished road
dremel tool, it is your friend
+ polishing kit, just to be more specific
Old 06-28-2006, 05:57 AM
Thumbs up Re: Cleaning/polishing help with lettering on rim
Hmmm...thought that's what I said. Maybe all Dremels are not friendly.
Old 06-28-2006, 12:21 PM
bob_fickel,
Bob, the paint can be removed with Aircraft paint stripper (don't use the odorless, it's not as strong as the other)
As stated above, in all likely hood you'll ruin the letters if you try to polish the background. BUT if you insist you can try dental burrs and a Dremel. It takes a real steady hand and a lot time. Another thought would be to polish the surface of the rough area and leave the "nooks" unpolished.
The "88" in the corner can be taken out with a die grinder and cartridge rolls. Again this will require a real steady hand as to not gouge the corner.
One thing that I would have attended to is that 'crack' at the edge of the hole in your picture of the rim.
All the supplies can be purchased at Caswells, they also have great tech support. Suggest you read the "sticky" on aluminum polishing this will give you more incite.
John
Old 06-29-2006, 11:36 AM
First off thanks for all input!
Second...I should have been clearer in what I was attempting to do. I just want to clean the areas of all piant. I am not trying to smooth area, just clean and buff, so it's shiny rough/raw texture aluminum.
I have used aircraft stripper on the rim to remove the paint (3X)...but the lettered area just won't come clean (also used brass wire brush with stripper). My latest idea, which I haven't tried yet ...use a spot blaster w/ baking soda as the blasting media.
Bob
btw
I was using the dremel with a cratex bit cleaning the paint out of the hole and guess what happened
