After polishing my bikes rear wheel several times I realized my error is not in the polishing but the drill. My drill isn't fast enough, it's only 2500 rpm and using a 4" wheel it isn't enough sfpm's to do the job right. Because of the shape of the wheel I have to use a drill and 4" wheel, nothing else will fit inside the wheel contours. Been looking around and I can't find anything over 2500 rpms, does anybody know of a drill that will get at least 3600 rpms?
Ha! As a matter of fact I went and bought a pnuematic mini die grinder today, 22,000 rpm, a little high but should work pretty good, now I just need a good compressor, the 120psi one I got just don't cut it....... |
I use die grinders for all kinds of work but they are air hogs for sure. The only other thing to get the RPM's would be a 4.5" electric angle grinder and get an adapter from Caswell. They have adapters to run the 4" wheels and others.
SS http://www.caswellplating.com/buffs/index.html |
| High Gloss paint to match powder? | DriKote | Powder Coating Questions | 1 | 05-19-2006 09:09 PM |
| high temp- how high? - will it burn? | mtnbiker | Powder Coating Questions | 6 | 09-26-2005 11:47 PM |
| high temp sheeting | craigcraig | Powder Coating Questions | 1 | 08-09-2004 12:15 AM |
| hand held drill...or 1/2 hp buffer? | shine | Metal Polishing Questions | 6 | 08-20-2003 04:42 AM |
| Can I use VHT high Temp with Krylon High temp radiator paint | magnus | Other Metal Finishing Questions | 1 | 05-03-2003 11:20 AM |
