Old 07-08-2006, 11:21 PM
jimmijet2841 is on a distinguished road
Default polishing ss knife blades
i want to polish some of my ss knife blades i have a die grinder that i will be using.can someone run through the steps and tell me what are the correct products to achive mirror finish.
also what is the difference between grease and greaseless compounds.
thanks in advance
jim
Old 07-11-2006, 10:13 PM
pickleboy's Avatar
Default Re: polishing ss knife blades
thanks in advance
jim
first off what is the finsh you are starting with? without seeing the blades i can make the following basic suggestion. start with a handful of the felt bobs that caswell has and some 320 greaseless compound. the use the 400 grit greaseless. then on to emory and then stainless(green) bar. finally if needed red bar.
the difference between greaseless and grease bars is the binder medium that the abrasive is in. almost all of the polishing bars except blue has some kind of abrasive in it. the grease bar flows a little aesier but the abrasive level starts about where the greaseless leaves off. hope this helps bro.
Old 07-11-2006, 10:23 PM
thanks for the imput i have finished the blades by sanding them starting with 400,600,1000 and finished them in 1200. that where i'm starting the polishing process from. i'm not sure if that changes anything. if it does please let me know. and once again thanks for taking the time to answer my questions.
jim
Old 07-11-2006, 10:35 PM
pickleboy's Avatar
jim
yes that changes the process greatly. since greaseless grit is close to equal grit of paper, then the 320 and 400 would be a great step backwards. i would start out with the felt bobs and green bar. if this does not give the lustre you want then back up a step to the brown bar or the black bar. then go foward again. as for the help, it is my pleasure bro.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 02:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Need Help polishing large flat section smooth72 Metal Polishing Questions 4 04-14-2006 02:22 AM
Dimensional influences of Brite Dip Polishing Aluminium whistule Metal Polishing Questions 0 10-03-2003 08:40 PM
Intake Manifold Polishing Dino6961 Metal Polishing Questions 2 09-05-2002 12:47 AM
