Old 08-04-2006, 03:37 PM
baldysm is on a distinguished road
Default rough polishing problem
I am trying to polish titanium sheet, that's pretty small. It's a pocket clip for a writing pen, so it's 5/16" by 2.5" or so.
I use a small rubberized polishing wheel (1" diameter) to remove alot of the gouges and such that are on the metal when I get it.
I'm having a heck of a time getting it polished flat. It looks like I have chatter marks on the surface.
I am using a 1" hard felt wheel with black compound on it. It doesn't seem to help much other than to make the chatter marks really shiny.
Any suggestions to buzz down the high spots on a piece this size? Once I get it rough polished, I bend the piece to the shape I need and then polish out any marks made by bending, and then bring it to a nice high shine.
Thanks
Scott
Old 08-07-2006, 11:40 AM
Default Re: rough polishing problem
Is the rubber wheel you are using a Cratex? To achieve a flat surface for polishing you must have a flat surface to start with. I would suggest using a flat sanding block with 120 or 150 grit wet and dry, wet sand until chatter marks are gone then polish.
I would try using a 1", 1 1/2" or 2" treated buff, with Emory to polish, then on to Tripoli and White to finish. Caswell's should have these.
John
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 03:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
Need Help polishing large flat section smooth72 Metal Polishing Questions 4 04-14-2006 03:22 AM
Frame polishing....same process...2 different finishes? HELP bairdmotorcycles Metal Polishing Questions 15 06-27-2005 04:13 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 09:12 AM
