Like the title says lets see some pic's of your work.
This is my 85 Sport Coupe that I have nearly fixed up completly. http://www.thirdgen.org/rides/rideimages/ACFmIX2CQ.JPG |
Mike, guess you did come check out the site. This forum is a little slower than thirdgen.org but you can't beat the prices on buffing wheels. Also, I order the rest of my buffing stuff today, guess I'll be giving it a try later this week.
-Matt (ions91z28 from tgo) |
Looks like a great job, but only 10 hours??
Awhh, get real, Surely you do jest, or are you serious? I would think the time to plate the parts would be nearly that long alone unless you have a really serious plating setup. What did you start with? Were these stock parts to begin with? Looks like you did a great job on them. Chromo |
Yes it really took me 10 hours to polish everything, it was all casted parts. I use to work in the Street & Performance polishing shop for almost a year so I got pretty good doing that almost every day. I did not plate those parts either, fellow member on another message board wanted his setup polished. Once again its not plated chrome. If it was I would have had less polishing to do.
If thats not chromed, what is the metal, aluminum? If so what did you coat that with to stop oxidation and hold the shine?
I have a firebird I'd like to polish out like that. Do some chrome and gold work on it too. It's a $150 car, needs tranny, but worth rebuilding. Body not bad some dents and dings but no rust, engine good. Makes a great rod to customize. What did you polish with, and how did you get into those tight corners? Maybe with your advice I can do in 6 months what you did in 10 hours Chromo |
All parts are aluminum and to keep them from oxidizing you need to clean them with some eagle one aluminum polish once a week to keep the shine. This is basically what I used when I use to polish at my frineds shop. I use a air powered die grinder with 120,320 grit sanding rolls and tapered rolls. A da sander with 120,320 grit glue on back sanding disks. I used a bench grinder 3/4 horse I think. Then a 6" sisal polsihing wheel with black grease, then onto a 6" cloth sewn wheel with tripoli grease, and finaly finishing it off with a 6" loose buff. Hopefully soon I will have my own polishing shop up and running.
Hmmm,
I could put the time into the polishing and hopfully get some decent results, but polishing/cleaning once a week! Don't think I could do that. I think I saw something about a sealer of some type to prevent polished aluminum from oxidizing on the caswell site somewhere. Or maybe it was a clear laquer coat? Have you tried anything to seal the parts? For my area of the country and no more than I'd use the car I'd need more of a seldom touch finish. Like hose off the road dust regularly and clean well every couple months. Unfortunatly aluminum does oxidize rather your using it or not, and I wouldn't be using it much. I live on a dirt road in a very humid area. I geuss if I couldn't seal it to hold the shine I would need to go with anodized, I don't think it oxidizes. Chromo |
| MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! | NautiShine | Metal Polishing Questions | 61 | 05-15-2008 02:03 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Dimensional influences of Brite Dip Polishing Aluminium | whistule | Metal Polishing Questions | 0 | 10-03-2003 08:40 PM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 08:12 AM |
| Brand Newbie Aluminum Polishing Question | gdsegel | Metal Polishing Questions | 1 | 04-25-2003 08:04 AM |
