Buy One, Get One Free Buffing Wheels
Old 01-29-2003, 04:22 PM
rpen
Default Polishing Aluminum Wheels
Ok, experienced polishers. I will mostly be polishing wheels (auto and big rigs). Also other car/engine parts. What's the best setup?
Handheld polisher? Drill? I was thinking of a 3/4 hp bench grinder with flex shaft for doing wheels in the shop, but that's not at all portable. What makes the quickest job?
Any suggestions/tips?
Old 01-29-2003, 10:55 PM
mcaswell's Avatar
Caswell Inc Founder
The BEST setup?....see http://www.caswellplating.com/buffs/lustre/marlin.html
It's a beautiful machine.
Have A Web Site?
Old 01-30-2003, 09:23 AM
rpen
Ok, I set myself up for that. It is a beautiful machine ...BUT...
1. I will be doing this part time.
2. Cost IS a factor (don't have 12 grand). Would like to spend <$1000.
3. I also want to be able to polish other parts (engine parts/auto trim/etc).
Let me be more specifc. For under $1000, what would you (anyone) suggest that I buy to set myself up to be able to polish anything from auto parts/trim to rims to antiques. I'm doing this both as a hobby and source of extra income.
If you can (I know I'm asking a lot ) be specific about what tools you use to polish certain items. I've done some polishing before, mostly by hand, and that is just too much work for too little result.
Thanks.
Old 01-30-2003, 01:24 PM
mcaswell's Avatar
Caswell Inc Founder
I expect that for big jobs, most people here are using a handheld buffer with 6" wheels.
An electric drill works well too, with an arbor adapter and 4" wheels. The smaller wheels make the job go more slowly though.
Have A Web Site?
Old 01-31-2003, 09:25 AM
rpen
Anyone else?
Old 02-01-2003, 06:18 PM
Josh
a variable speed dremel for the small antique parts will work well
Old 02-02-2003, 03:53 PM
mcaswell's Avatar
Caswell Inc Founder
I found a great resource for everyone. It specifically discusses polishing rims. The author is a customer of ours.
http://www.78ta.com/rims.htm
Have A Web Site?
  #8 (permalink)
Old 02-04-2003, 09:51 PM
CamaroMike's Avatar
CamaroMike
polishing rims is easy once you get the hang of it. Heres one of my own. Please excuse the crappy paint it sucks I know, and I dont have hub caps cause I plan on painting all my rims when it gets warm enough to work on my car outside.But at least the polished part is good.
  #9 (permalink)
Old 02-05-2003, 01:40 PM
rpen
CamaroMike, what tools/methods do you use for polishing wheels?
  #10 (permalink)
Old 02-05-2003, 02:03 PM
CamaroMike's Avatar
CamaroMike
I use a air powered die grinder with 120,320 grit sanding rolls and tapered rolls. A da sander with 120,320 grit glue on back sanding disks. I used a bench grinder 3/4 horse I think. Then a 6" sisal polsihing wheel with black grease, then onto a 6" cloth sewn wheel with tripoli grease, and finaly finishing it off with a 6" loose buff.
This is my 85 Sport Coupe that I have nearly fixed up completly.
http://www.thirdgen.org/rides/rideimages/ACFmIX2CQ.JPG
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Polishing Aluminum Wheels With Dremel bluews6 Metal Polishing Questions 4 01-19-2005 02:19 AM
Need Help Polishing aluminum Wheels. mattyp Metal Polishing Questions 13 06-14-2004 08:44 PM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
Polishing aluminum motorcycle wheels emprcyrul Metal Polishing Questions 7 02-15-2003 10:28 AM
