Originally Posted by 87_ttop_stang
Hello all!
I purchased a new bench grinder this weekend (sears had a nice sale fri-sat), so I am also going to order some buffing supplies.
I've had my eye on the expander wheel for some time to help me with some of the larger "under the hood" pieces I want to work on.
Does anyone here use it, and if so, what are your thoughts? Good. Bad. Okay. Can you recommend a better way of handling things like valve covers and large brackets?
All comments welcome.
Thanks!
It's a good tool for smaller items, but on stuff like valve covers I've discovered that my manual skills aren't sufficient to use it. It's only about 1-1/2" wide and it's tough to make multiple passes on a surface without the edges digging in and leaving marks. That's on aluminum...it's better on stainless (like brake rotors) 'cause the material is harder.
All that said, they are a great tool and quick to change grits if used properly.
BTW they are subject to direction of rotation and rpm's so make sure your motor is suitable.
