Old 10-08-2006, 08:09 PM
sslayden is on a distinguished road
Default Streaks in SS firewall
Hi all. I'm polishing a SS firewall using the Caswell SS polishing kit. All is going well except that I can't seem to get rid of what looks like streaks. I think it is slightly un-eaven polished vertical lines. I'm using an Hitachi 3400 rpm 6" buffer . I'm at the stage of using the green SS compound with just the color cut. I'm polishing only vertically on the firewall. Should I be using some other pattern such as alternating 90 deg? I've been polishing it for quite a while, too Any ideas?
Old 10-08-2006, 08:57 PM
pickleboy's Avatar
Default Re: Streaks in SS firewall
yes when possible you should alternate at 90 degree angles on each step of polish work. this will help show you where you need more cutting if needed and break the pattern/ wave lines.
Old 10-08-2006, 09:03 PM
Great, thanks for the quick response!
Black streaks, scratchs & Haze... bling88 Metal Polishing Questions 20 08-13-2006 04:33 PM
Dark streaks in CopyChrome 7 Adjusting PH vegas_m Electroplating Questions 6 09-11-2005 02:12 PM
Black Dye problems/Smears and Streaks Easttex Anodizing Questions 1 07-16-2004 09:43 AM
Scratches or streaks? fosgate99 Metal Polishing Questions 2 10-03-2002 03:20 PM
