Old 10-09-2006, 02:42 PM
edge4you is on a distinguished road
Default newbie in polishing aluminum
I have some aluminum parts on my bike I want to polish, the handle bar control covers, master cylinder and brake levers. The control covers have some clear coat on them some of the clear has worn off hence why they need polishing. I am going to by Caswell aluminum polishing kit. Questions are: do I need to by stripper to get rest of clear coat off or use the compounds that come with the kit I have read the forums and not really sure witch way to go. 2nd do I need to re clear coat when done or use another type sealer and finally if anyone has any advice it would be greatly appreciated
Edge4you
Old 10-09-2006, 03:59 PM
alabama_lowlife will become famous soon enough
Default Re: newbie in polishing aluminum
you should get some aircraft stripper to strip off the clear coat unless it is anodized, in which case you'll need some easy-off oven cleaner to strip. in order to keep a maintenance free shine, you can reclear or use zoopseal. caswell sells a clear coat that is safe for high temp applications.
Old 10-09-2006, 04:13 PM
Question Re: newbie in polishing aluminum
thanks for the info
now does the easy-off strip the clear-coat or the anodize
Old 10-09-2006, 06:41 PM
easy-off is for the anodized, acft. stripper is for clear coat.
Old 10-09-2006, 11:02 PM
pickleboy's Avatar
lowlife gave great advice on this. i will add that if the clear looks like a paint and is flakey at the edges then the stripper. if it feels like its gritty or chalky then its ano.
Old 10-19-2006, 11:32 AM
boston_jake01 is on a distinguished road
how can you tell what is cear coat and what is anodized.
also I am thinking of polishing the jugs (cylinders) of my harley what and how would you recommend.
Thanks
Old 10-19-2006, 12:47 PM
pickleboy's Avatar
Thanks
i can say from my own harley there is almost nothing that is ano. it is all powder or clear coat.
as for the polish work on jugs be prepared to spend lots of time on them. caswells sells some very thin buffs that can be used on a die grinder that should be able to get between the cylinder fins. that along with lots of sanding and you can get a nice shiney engine.
  #8 (permalink)
Old 10-19-2006, 05:55 PM
thanks for the help I guess I got alot of work ahead of me.
why brown before white polishing aluminum? PRO'S PLEASE READ insomniac71 Metal Polishing Questions 9 05-24-2008 01:08 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
input on aluminum polishing and need help choosing a buffer Sid03 Metal Polishing Questions 7 08-09-2004 10:21 AM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
Brand Newbie Aluminum Polishing Question gdsegel Metal Polishing Questions 1 04-25-2003 08:04 AM
