Re: new and looking for some advice
Originally Posted by
chaotik
You want to use a loose cotton wheel with the white bar...a spiral sewn might be alittle too aggressive and wont give you the shine you are wanting.
But, you can give it a try and see what your results are.
that is not always true. i have found from lots of hours in the shop polishing, that on most aluminum the loose white combination is not the end all. i get a better shine with the spiral and white. i also use red and spiral. the loose wheels can cause a slapping action on the part that can actually cause more haze/scratching than the more solid face of a spiral.
