Old 10-29-2006, 03:47 PM
daz2206 is on a distinguished road
Send a message via MSN to daz2206
Default my polished alloy has a gold metalic look to it
Hello.... this is my first post on the forum and im new to polishing, ive been polishing my car engine covers but some parts have a gold metalic look to them after being polished. ive spent at least 100 hours on it so far as i made the mistake of starting with 80 grit wet/dry sandpaper (if id used paint stripper first i would have seen that the alloy was already smooth under the mottled effect paint but i know for the future lol) im learning quite a bit from the forum and think im slowly getting there, ive used the search but i cant seem to find anyone else having this problem (maybe nissan skylines use cheap alloy ?) here is a pic of my engine and you can see at the front (cambelt cover) what i mean, its worse when the sun shines on it but its still noticeable whatever light shines on it, any help would be much appreciated. (i apologize for the size of the pic, i dont know how to make it smaller)
Old 10-30-2006, 06:54 AM
Default Re: my polished alloy has a gold metalic look to it
Looks pretty good to me - I can't really see any gold color on my monitor. Unless you're "burning" the material during polishing, I don't think there's anything to be done about color variations. Of course if it bothers you much you could always anodize it all dayglo pink or something...
Old 10-31-2006, 03:58 PM
grommit's Avatar
grommit will become famous soon enough
looks like for a beginner like me you are gaining the experience and knowledge passed on by all the helpers on this site, my friend has the same problem with his skyline and all i can think of is heat, i have done quite a bit on his car for him(rectifying his ?!*£ ups!!) he is happy with the results, but if i were you i would consider mpierich's suggestion as you know it will only work on your mind, as by the picture you are a guy who strides for perfection in your car...it took me aprox a year of getting help of the guys experimenting etc and learning by mistakes etc befor i got confident to do jobs on expensive parts or for other people,so you have done well.
take care,
Grommit
Old 10-31-2006, 04:30 PM
thank you for the replies, if ive burnt it, is it possible to start over or will it be like this right through the alloy ? il take a very close up pic tomorrow and hopefully someone might be able to tell better where ive gone wrong.
Old 11-01-2006, 01:25 PM
Maybe try taking a small section of the yellow part back, starting with 320-grit or so, then working back up to a polished surface (being careful not to overdo it on the speed and pressure) and see if there's any difference. If you did "burn" it, it should only be on the surface.
Old 11-17-2006, 01:20 AM
twinturbo_rotary's Avatar
twinturbo_rotary is on a distinguished road
in your picture it looks really good, did it turn yellow after time or was it like that when you polished it?
the rb26 is cool engine what model is your car R33 -R34 ?
Old 11-19-2006, 03:03 PM
it turned gold metallicy looking as i was polishing it, its an r32 gtr (1994)
  #8 (permalink)
Old 11-21-2006, 03:36 PM
R32 nice, i think there is no way to get the yellow tint off, when i took cast aluminum engine parts to my friends shop to get tig welded he told me that it might not look as good as it could because the cast aluminum absorbs oil and its hard to get out, so i'm thinking that the yellow gold color on your valve cover is just is from oil.
  #9 (permalink)
Old 11-21-2006, 05:14 PM
thanks for the help, i have loads and loads of skyline bits to polish so il have another go and see how they turn out, i think im getting a little better at polishing since i did my own covers (thanks to the guys on this forum) so hopefully the next bits will come out better than the ones in the pics.
  #10 (permalink)
Old 11-22-2006, 06:09 PM
mojoe
I can see aluminum absorbing oil over time.
Just a thought that popped into my head......what about heating the part in an oven?
you know....like prepping for powdercoating in order to get the contaminates out of it. think that might work? maybe as it cools down a bit so as not to shoot off too much smoke, spray it down with some acetone or carb cleaner. then give it a good cleaning before starting the polishing process.
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 09:11 AM
Going For The Gold gsw3 Electroplating Questions 3 09-11-2005 12:18 PM
How about Gold on Gold ? Ra Electroplating Questions 5 10-12-2004 07:47 PM
Silver polish on 24k gold plate?? chromo Electroplating Questions 3 04-07-2003 05:14 AM
gold plating on brass jomida Electroplating Questions 5 02-23-2003 10:34 AM
