Ok I am very new to this and I have some aluminum trim pieces that I am trying to polish. The pieces have been sanded all the way to 1200 grit to get out all scratches. Then buffed using emery/sisal white/sprial, and lastly red/flannel. The buffing machine I am using is a 1 1/2 hp 1750rpm motor ( I know this is slow) I am using 10" buffs.
The problem I am having is during the final red rouge polishing. After the white, the piece is nice and bright (mirror like). When I go to red at first I was getting this nasty trail of compound during my color stroke which i figured was to much compound on the wheel. Raked the wheel and tried to used up some of the compound on a scrap piece. Now I dont get the nasty trail but once I do a light color pass the part looks dull. I tried washing the part with soap and water, degreaser, nothing seems to work. The part just comes out dull/cloudy looking. Maybe speed of wheel?? I dont know. Any help would be appriciated thanks |
Also...I do believe that if you're going all the way to 1200 with the sanding, the sisal is too aggressive. Maybe try a spiral or loose wheel for the emery. |
I agree but I would just like to figure out what in the world is causing this problem. Cause I would like to be able to brighten it up just a touch. I will try using a sprial instead of the sisal cause it is pretty aggresive for what im doing
thanks |
Ok, well today I got a minute and tried a couple pieces out with white/loose wheel and red rouge/loose wheel. I tried 1 exterior trim part and 1 interior trim part. With the white compound both pieces came out very very shiny but the interior trim piece had what almost looks like little light specks below the surface (cleaning it throughly did not remove them) and you can only see them in certain light and it seems like they kindda dull the part. However the exterior trim piece came out excelent, highly reflective in every angle of light. I am starting to wonder if maybe a cruddy grade of aluminum was used on interior trim and it is actually a problem with the aluminum and not my technique. Anyone have any ideas?
Also I tried the red rouge at a higher rpm (about 2700) and still got the cloudy results as before. I will probably just stop at the white compound as it seems to do a fine job but would like to know what could be the problem with the red as well. Hopefully this has happend to someone on here or someone has some insight. thanks |
when i polished my plenum, there was alot of that white speckled look to it that i just couldn't get out. i think it has to do with the quality of the casting. i also recommend trying one of caswell's cushion buffs instead of the loose to use with the white. white is the last stage i use.
With this problem I always go slower in speed rather than faster. It makes a big difference without the fibers slapping the metal so hard. But I still think the white rouge finish is dandy. |
thanks |
| Copy Cad Plating - Keep getting dull finish | dmcclain | Electroplating Questions | 3 | 04-18-2005 11:07 PM |
| polishing 6061 aluminum w/bad results | clockman | Metal Polishing Questions | 6 | 05-16-2004 05:41 PM |
| Bad Polishing Results | kenykirschstein | Metal Polishing Questions | 4 | 01-08-2004 05:27 PM |
| Stainless Steel pot + Dye = Poor results? | NeoMoses | Anodizing Questions | 2 | 01-08-2004 03:56 AM |
| Dull zinc wanted... | fargap | Electroplating Questions | 1 | 09-28-2002 12:47 PM |
