I wanted to know what kind of wheels you would use to buff a boat.Iwill do all the sanding.Then I would start polishing but I am pretty sure I would not use a wheel like I use on my bench buffer would I .If not what type cause it is a fairly large area it would take forever thanks for any reply.
polishing boat parts that have either soft or hard anodizing on it is not advisable moast parts are coated and when you start to sand or grind you will find your destrying the part wile trying to remove the coating instead of properly striping the old fishing then polish and re-anodize gmfinishing@verizon.net
does this type of work cause any damage?
boat parts |
| why brown before white polishing aluminum? PRO'S PLEASE READ | insomniac71 | Metal Polishing Questions | 9 | 05-24-2008 01:08 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Polishing Aluminum with new polisher? | scocklin | Metal Polishing Questions | 3 | 07-21-2005 01:53 AM |
| input on aluminum polishing and need help choosing a buffer | Sid03 | Metal Polishing Questions | 7 | 08-09-2004 10:21 AM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 08:12 AM |
