The problem that I am having is that I cannot get rid of the light scrathes. I have a great finish, but it is not smooth and scratch free. I started with Tripoli rogue on a spiral sewn buff the went to White rogue with a loose section buff. Ihave followed this up with a Jewelers rogue on a Canton soft buff hoping to get rid off all the scratches. I have gotten rid of most of the scratches but I have the scratches from the Jewelers buff. I am using 4" buffs on a motor that turns 1500rpm. I am applying medium to light pressure and using a criss-cross pattern to polish my pieces. PLEASE HELP ME TO GET RID OF THE LIGHT SCRATCHES IN ORDER TO ACHIEVE A SMOOTH MIRROR FINISH! I am so frustrated. Thank you for your help. |
I started polishing with 4" buffs on a drill that turned 2800rpm and did not get great results, plus it took forever to get the results. I recently tried some 6" buffs on the 3500rpm bench grinder where I work and all I can say is the difference was very noticeable
Check out ebay, you can pick up a super cheap bench grinder that'll spin way faster than your drill. At least step up to the 6in. buffs on your drill, trying to get the casting marks out of my rocker box covers, and aluminum wheels was taking forever with the 4in. ones. Good luck, Brian |
Thanks blip01. I have stumbled across a 1/2hp, 3500rpm, 6" bench grinder. I am finding that it cuts my polishing time in half! Especially when i am using it to smooth out my aluminum with 320 grit grease.
I have polished all of my pieces with brown and from 2 feet away they look perfect. It is when I look at them closely and angle them just right in the light that I can see all the superficial scratches. I tried going to white on a 6" loose wheel, but the scratches remain. Is it possible to get rid of these scratches completely no matter how it is viewed in the light? If so please help. This is keeping me from putting my bike back together so that I can start riding. I am hoping to have my bike ready for 2003 Daytona Bike Week and these aluminum parts are slowing my progress. Thanks! MM |
Blip,
I went to a 6" loose and used a red (jeweler's rogue) on my bench grinder. Using the afore mentioned criss-cross pattern, I was able to get rid of almost all of the scratches. I am not sure if it is the rogue that I am using but now I have a haze on my aluminum. I cleaned the metal with acetone, but to no avail. I know it is not the metal because the haze was not there when I was polishing with brown. I have ordered some FLITZ polish hoping to solve this problem. This polishing process (criss-cross) seems to work great on flat or rounded surfaces but the more advanced parts (like triple trees) cannot benefit from this process because of their shape and size. I tried a dremel, but had no success. I may have to live with the "2ft look" on this part. I also tried the talcum powder, but i did not have any luck. I agree. Stop hoarding all the SECRETS. We need to work together for a BRIGHT and SHINY future! Thanks for you help. MM |
Great! I just picked up some red rouge today too and hope that will get me that little bit farther I need to be happy. I also found a decent book on polishing aluminum http://www.powells.com/cgi-bin/bibli...1-0972461809-0 It covers all the basics, great for begginers. No huge secrets revealed but it's extremely thorough about the whole process. The most important thing I took away from it was keeping parts SUPER clean bewteen each buffing step and avoiding ANY cross contamination of compounds. I am going to try a way more thorough approach to cleaning parts, hands, etc. between each step and see if my results are better. Well worth the $11 bucks for the book if you're just starting out.
I too have my bike in pieces and need to get crackin'. Good luck. |
You might want to save yourself the $11 and read our free buffing booklet at http://www.caswellplating.com/buffs/buffman.htm
It covers all the basics of polishing any metal.
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| How do you remove chrome from aluminum wheels? | acmepowder | Electroplating Questions | 3 | 10-01-2007 06:40 PM |
| Really Fine Scratches - 1973 Aluminum | asallwey | Metal Polishing Questions | 4 | 12-04-2004 12:23 AM |
| cannot remove scratches | clockman | Metal Polishing Questions | 5 | 08-01-2004 09:13 PM |
| Tiny scratches revisited | VTXer | Metal Polishing Questions | 27 | 10-04-2003 10:32 AM |
