  #11 (permalink)
Old 01-29-2007, 03:42 PM
UncleJimmi is on a distinguished road
Default Re: Help Polishing GSXR 1000 subframe
All the GSXR's I have polished (5 or 6) have had anodizing on them.
That can give the look you are describing. If the bike is completely stripped of all other parts, motor, electrics, bearings, ect... you can remove the anodizing with spray oven cleaner. DO NOT walk away, let the oven cleaner foam up for 5 min and during that time you can spray it 2 or 3 times to keep it covered. Then rinse well with water and green scrub pad, repeat the proses if needed.
WARNING This may not be the most proper or legal way to do this.
DO NOT breath the fumes or let the oven cleaner contact any part of your body.
You may see results that are scary at first, but once you go back to sanding, things should go allot quicker.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 02:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Need Help polishing large flat section smooth72 Metal Polishing Questions 4 04-14-2006 02:22 AM
Dimensional influences of Brite Dip Polishing Aluminium whistule Metal Polishing Questions 0 10-03-2003 08:40 PM
polishing my GSXR frame ARP Metal Polishing Questions 1 05-05-2003 09:16 PM
