Old 12-16-2006, 12:57 PM
btorres09 is on a distinguished road
Default Help Polishing GSXR 1000 subframe
Help please...i am trying to polish my subframe off a 06 gsxr 1000 and while sanding it i can see what looks like veins in the metal...and for some reason i can seem to get rid of them....i dont want them to ruin the shine at the end process by showing up....can some one off some assistance
Old 12-16-2006, 01:20 PM
jrow is on a distinguished road
Default Re: Help Polishing GSXR 1000 subframe
btorres09,
Are you seeing "veins" or mold marks? Picture?
John
Old 12-16-2006, 03:00 PM
ninjinja is on a distinguished road
I have been working on a GSXR frame myself and seen the same thing, if you are seeing what I think you are seeing, in the sanding process but I found that they came out during the polishing process, some needed a little extra pressure but with a little persuasion they dissapeared. but to determine if we are talking about the same thing it would be better to see a photo.
Old 12-16-2006, 06:10 PM
thanks for the reply guys...im working on getting a pic...but they look like veins....im new at this so i have never seen anything like that....the only thing i have polished so far is a heel guard with no problems...another question. after using emery/sewen,then brown/ canton, then red/ sewen, then white/ loose i can see my reflection but for some reason it looks dull and dark....
Old 12-17-2006, 12:29 AM
lcaswell's Avatar
Caswell Inc President
Your steps are wrong, as are your wheel/compound combinations. Please read the buffing booklet at http://www.caswellplating.com/buffs/buffman.htm
Lance Caswell
Have A Web Site?
Old 12-17-2006, 04:41 AM
the steps i used i got from the polishing 101 class at the top of this forum...i new sorry for the stupid questions....i didnt have a sisal wheel so i used a spiral sewen one with the emery...other than that where did i go wrong...thanks for your help in advance i appreciate it....
Old 12-17-2006, 12:12 PM
btorres09,
Buffs in relation to there hardness would be Sisal, Sewn and Loose. Now in between the sisal and the sewn would be treated airway and untreated airway buffs. Compounds according to there coarseness would be Emery, Stainless Steel, Tripoli and White. Yes you can use Stainless Steel compound to buff aluminum if it get you the desired effect. A lot of polishing can depend on the type of aluminum that you are polishing IE, if you can polish the aluminum to the finish that you want using Tripoli and a sewn buff as your last step thats fine. You want to use a dedicated buff for each compound and rake the buff often.
Obviously this is over simplified but I think you get the picture.
John
  #8 (permalink)
Old 12-17-2006, 12:24 PM
Thanks for the info John...im going to try it out and see what happens...I appreciate the help....
  #9 (permalink)
Old 12-17-2006, 12:25 PM
Has anyone polished a subframe off a 2005-06 gsxr 1000 and has pics to show....
  #10 (permalink)
Old 12-29-2006, 02:16 PM
gbtweedy is on a distinguished road
Try doing a search on gixxer.com for a polished swingarm. Sometimes you cant get a cast piece to look perfect.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 02:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Need Help polishing large flat section smooth72 Metal Polishing Questions 4 04-14-2006 02:22 AM
Dimensional influences of Brite Dip Polishing Aluminium whistule Metal Polishing Questions 0 10-03-2003 08:40 PM
polishing my GSXR frame ARP Metal Polishing Questions 1 05-05-2003 09:16 PM
