Can someone please take some time to tell me everything i need to do and how to do it correctly to get a show shine. There is a coating on it now from the factory. what would you use to strip it off first?? I also have a alum. pulley with a black coating? how would i remove it?? i think its black powder coating, so i can polish the pulley. thanks sorry for all the questions. http://www.stiegemeier.com/show_polish.html |
for the pulley if it's PC, then aircraft stripper will take that off. if it is anodized, easy-off oven cleaner will work. same for the blower itself, if it's a clear paint, stripper. if it's anodized, easy-off.
as far as polishing it, i'd use some sort of flexible shaft grinder. i got a cheap one i got off ebay that came from harbor freight originally and it's great for me. probably not the thing for making a living off of, but i do it because i like it. if you've got a regular bench grinder, you can use it instead of a real buffer. caswell sells a thin razor buff that is GREAT for getting between fins like are on that blower. not sure of how much space is between those fins, but a regular sewn wheel might fit in there too. go ahead and get the treated wheels, it's worth the money for those. if the original finish has alot of pitting from the casting, you'll want to use greaseless compounds to cut out the hand sanding. |
http://www.svtperformance.com/forums...polished+eaton
here is a couple pictures what the sc looks like polished?? i'm just worried about how to sand all the tight spots, do you use soft wheels with the greasless compund or sanding bits? |
John |
Anybody know how these things start out? Are they cast or smooth to start with? I'm still doubtful about the vibratory tub taking aluminum from cast to polished - especially since I haven't found anybody who's actually done it. |
mpierich,
The reason I suggested that it was polished by a vibrator, was that the gasket surfaces are polished. Not something you would do when you hand polish, at least something I wouldn't do. John |
Speaking of superfluous polishing, I've seen people do stainless brake rotors and they do a show polish on the braking surface while they're at it. Pretty, but totally unecessary and possibly dangerous. |
Here's a different s/c but the casting is about the same rough! http://www.stiegemeier.com/images/bl...en_blower4.jpg http://www.stiegemeier.com/blower.html |
| MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! | NautiShine | Metal Polishing Questions | 62 | 05-18-2009 02:23 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Need Help polishing large flat section | smooth72 | Metal Polishing Questions | 4 | 04-14-2006 03:22 AM |
| Dimensional influences of Brite Dip Polishing Aluminium | whistule | Metal Polishing Questions | 0 | 10-03-2003 09:40 PM |
| A ? regarding polishing aluminum wheels... | geotexZ71 | Metal Polishing Questions | 4 | 04-25-2003 09:12 AM |
