I am polishing an intake manifold and would really appreciate some suggestions on the quickest way to remove the cast marks. I tried a sanding drum with a dremel but it seems a bit aggressive and the drums last 5 minutes. I also tried a 1 inch 120 grit flap wheel, that went well but I went through the flap wheel in 20 minutes. Are there any other ways to do this? Thanks in advance.
I used to start with 80 grit, but 120 is plenty. If I use 120 cartridge rolls I then also usually go over it with 120 greaseless to get rid of the ripples. Do an archive search, there's plenty of stuff in here... |
I have a few questions. Can I remove casting marks with a palm sander and sandpaper? Would felt bobs and small wheels with greasless work well with a 3000 rpm drill?
ive been buying all sorts of tools lately to find the best things to use. Im currently doing an inlet manifold too. Ive blasted the inlet with a 120 grit aliminium oxide grit first to clean it down. I then bought a sanding kit like this
![]() ive sanded it down to the best i can with the pads but they cant get in everywhere but have taken out the roughest surfaces. Then ive gone into greaseless on felt bobs with a dremel. Like said above its the longest process, you load it onto the felt bobs, then have to let it dry hard ( quicker with hairdryer ) then sand away, when the greaseless has worn off the felt bob ( which it will do fairly quickly ) then just reload your felt bob and carry on. Ive bought a range of felt bob sizes and can get into most places on my inlet now so its just a case of getting on with it. here's what the greaseless looks like ![]() Hope this helps |
this is the inlet manifold im trying to polish, so you can see how hard its going to be lol.
dont know how id do it without greaseless now. ![]() ![]() |
For removing casting marks on aluminum try using a diamond impregnated fingernail file. It's easy to control and it cuts pretty fast. After you use that take some 150 - 220 grit paper and finish it up. You can also use a 6" metal file, make sure that you keep the teeth clean as they will clog pretty easy. Die grinders and cartridge rolls are great, but they will gouge the aluminum if you are not real careful.
John |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Black dots in the cast aluminum | dekebell | Powder Coating Questions | 0 | 04-11-2006 09:23 PM |
| Removing oxidation from cast aluminum? | Helf8704 | Powder Coating Questions | 1 | 02-10-2006 09:16 PM |
| Polishing cast aluminum | turbohardtop | Metal Polishing Questions | 26 | 07-05-2005 10:10 AM |
| Cast Aluminum | scocklin | Anodizing Questions | 5 | 12-03-2004 11:38 PM |
