Tried a search but had no luck!
I am using a Dremel tool to do the cleaning and polishing on this headlight motor off a Mazda RX-7. What attachments would you use to get into the tight corners to sand it down ready for polishing? It dosn't need to be a mirror finish, just nicer than what it is currently! For an idea on size, the nut in the top pic to the right and the bottom of the lower pic is 8mm. ![]()
Use these with greaseless compounds to smooth, then the polishing compounds to make it shine. Perhaps someone else can comment on Cratex (rubber) tools - I haven't tried them yet. |
mr_rotary,
If you just want to clean it up, I'd try some Comet and a toothbrush. It will probably be abrasive enough to clean the aluminum up some. If that doesn't polish it enough try what mpierich suggests! Clean it with Dawn dish washing liquid and water when you are finished. John |
i got some 12mm felt bobs from ebay. and the same guy i got them from sells much smaller ones. caswell ought to get these, they're really small and do good in tight spots.
http://stores.ebay.com/Felt-Bobs-and...QQftidZ2QQtZkm |
| Polishing tool steel follow up | DougT | Metal Polishing Questions | 5 | 07-19-2006 01:37 PM |
| Polishing tool steel | DougT | Metal Polishing Questions | 3 | 07-03-2006 12:28 PM |
| Polishing tight corners. New guy. | chefboiali | Metal Polishing Questions | 31 | 06-19-2006 05:37 PM |
| Tips on polishing inbetween letters and in tight corners | tomg552001 | Metal Polishing Questions | 2 | 03-13-2003 02:29 PM |
