Is there a kit to get the brushed stainless look? I have two stainless and one nickel plated pistol slide that I would like to give a brushed or satin look. I have a 1 hp grinder/polisher in my shop. Any advice is welcome.
Rick |
Hey Nick, don't do the nickel one, the plating is soft and thin. Stay with a cream polish for that one unless you are going to have it re-plated.
You can do the flat sides by putting sticky sand paper on a hard flat surface and carefully rubbing straight through the strokes. You can also try clamping the gun slide in a way that you can hand sand with a hard foam block. The finer the grit the brighter the grain. I always get it real close then go back a grit to finish it off. Example: 120, 220, 320, then back to 220 for the final pass. At this point you may also try using an abrasive scrub pad to soften or blend. Hope that helps |
| Weber 40 IDL die cast body finish | miura | Other Metal Finishing Questions | 7 | 01-31-2008 11:12 AM |
| Copper-fired finish, How to | cottages | Electroplating Questions | 2 | 08-01-2006 11:01 PM |
| Newbie, trying to find best way to finish aluminum-LONG POST | chik | Metal Polishing Questions | 6 | 03-14-2005 08:11 PM |
| can we identify this finish? | funkmunky | Electroplating Questions | 3 | 12-15-2004 08:45 PM |
